battery drain, next steps...
Old May 20, 2004 | 08:50 PM
whtlightning's Avatar
Car: 89 TTA
I finally got around to investigating a nagging battery draining issue I've had for a while. Using a test light approach I discovered that my "CTSY" (courtesy) fuse is the problem. My question is how do I pinpoint the issue beyond here? I've checked connections on the cigarette lighter and dome lights. Should I check the relays? If so does anyone know where they are located? As you can tell my wiring knowledge is limited. Any insight is appreciated.
Thanks in advance,
Justin
1989 20th Anniversary Turbo Trans AM
Old May 23, 2004 | 03:30 PM
Vader's Avatar
Aside from the interior lights and cigar lighter, other things that share that circuit feed are:
Clock input to radio;
Rear hatch release/pulldown;
Horn Relay;
Map lights;
Power antenna;
Center console lamp;
Cargo well lamp.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
