help!!!!! my engine sounds like a popcorn machine
my L69 is giving me fits. it refuses to run smoothly. when i hit the accelerator it just bogs and pops with no acceleration. i bought the car minus the computer, so the carb is unplugged and i can't tune it. please help me resolve this situation
is it using the cc distributer?
If it is ccd i would say go and buy a comp.
If it is not a cc disributer i would recomend that you get another carb.
People have used computer controlled carbs but they run like crap they dump fuel like gas is free. Just get an old style qjet, holley or edlebrock whatever you are most comfortable working on.
Car: 84 T/A
Engine: 305HOL69
If you get a non-CCC, yes you will need a vac-advance distributor.
I've got one if you want to go this route, pulled it out of my L69 when I resurrected the computer. Drop me an email if you want the thing, i'm in Orlando.
Otherwise the computer is replaceable. I got one from Discount Auto Parts for about $80 after core. Only thing is you have to reuse the original chip, or put in an aftermarket one if you don't want the stock chip.
Keep this in mind if you delete the ECM, though: If your car has an auto tranny, you'll need to get a pressure switch put in to control the Torque Converter Lockup. or wire it to a toggle and control it by hand otherwise your tranny will burn up (ignore this if it's a stick shift)
DR Stevens
Car #1: my ride
1984 TransAm
305HO(L69) 96K & counting
750 cfm Q-Jet/Holley rem.
K&N filter
700R4/Superior shift-kit
and trans cooler
3.42 rear/3.73 blew up!!
underdrive pulleys
Accel HEI Super-Coil
180 stat/hi flow water
pump/Jet fan switch
dual snorkel/'84 ram air
3" exhaust of some sort
partial emissions delete
Car #2: My wife's ride
1991 Firebird/Formula
305TBI(LO3) 99K & smoking
K&N air filter
Hypertech Chip
more engine mods later
"Hey, Uncle Sam!! Where's my f**king tax return??!!"
DR Stevens
Car #1: my ride
1984 TransAm
K&N filter
and trans cooler
underdrive pulleys
pump/Jet fan switch
K&N air filter
Hypertech Chip
