How high of PRMs should I be making power with these mods...?
Okay, with my LT4 HOT cam, the car pulls good till about 5000 or so, then it runs out of breath because my TPI is stock. I am however getting a new Accel Intake base in the current GP, do you guys think that will help my car pull till 5500+? Also, I have new valve springs from TPIS, so I will be able to safely rev the engine over the 5500 red line and be okay, right?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
L98 TPI 350 (5.7L)
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Sounds good to me. Did you check for coil bind and piston-to-valve clearence when you put the cam in? My engine pulls to 5500 and a little bit beyond with the LT4 HOT cam and TPIS intake/runners. I've also got an AFR Hydra-Rev kit.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
I didn't check for those things as I didn't know I was supposed to or how do even do it. Reguardless, the car runs great now and I know there is plenty of piston to valve clearance, although I have no exact numbers. Anyway, the car should breathe pretty high I hope!
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Did your car actually get faster with stock heads and that cam? Somehow, I doubt it. I have seen that cam slow down cars with more mods then you have.
theshackle
Sep 17, 2020 08:26 AM
Linson
Aug 21, 2015 02:12 PM
