HELP just lost 3rd and 4th gear!!!!!!!!!
Old Mar 26, 2001 | 11:15 PM
Brandog87GTA's Avatar
Well it wont shift into 3rd or fourth now. I installed the b&m shift kit a while back and about a month ago it started slipping on the 2-3rd shifts, now it just revs up and wont go into 3rd or 4th. there arent any bands to burn for these gears correct? Could my clutch plates be bad?? What does this sound like to u???
Bright red 87 GTA with I have stock 3.27 gears,stock converter,B&M shift kit, TRW forged 9.75:1 pistons,comp cams pushrods, edelbrock valvesprings, 462 camel hump heads with 2.02in/1.60ex redrilled for angled plugs, 3 angle valve job, ported and polished, performer RPM intake, mallory fp regulator, edelbrock 750 CFM carb, hei ignition(new) with 10,000 volt coil,No cat, flowmaster 2 chamber mufflers, hedman full length headers, edelbrock cam with 488/501
Old Mar 27, 2001 | 12:08 AM
Come on someone help me out...
Old Mar 27, 2001 | 05:57 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
3-4 Cutches are burnt. Not unusual to see this. There is no "quick fix" other than to remove the tranny and have it repaired. I am currently repairing a fellow members tranny now for the same thing. We put Raptor's 9 clutch setup instead of the stock 6 clutches. That should hold it pretty well. Sorry about your tranny.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 27, 2001 | 09:11 AM
Well I didnt really wanna hear that, but thanks for the input. Guess its off to rebuilding I go...
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Warlocksirix
Sep 3, 2015 12:26 PM
crazynights
Aug 21, 2015 06:53 AM
86White_T/A305
Aug 17, 2015 12:16 AM
