Removing valve springs while in car
Old Mar 27, 2001 | 10:29 AM
Tab92bird's Avatar
I have some new valve springs I bought in anticipation of a cam swap soon. However, I don't have a compressed air source (with the exception of a little compressor w/o a tank) to hold the valves in. Also, I read somewhere that i have to replace the valve seals too, something I'd rather not do because they don't leak at all. would it just be easier to buy a little air tank, or is there another way to do it?
Thanks,
Brandon
White '92 Firebird w/ 305 TBI. Open element w/ non drop base, increased fuel pressure, TBI spacer, Hedman Hedders & y-pipe, no cat, cat-back exhaust
Old Mar 27, 2001 | 10:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can do it without air if you remove the spark plugs; one at a time bring each cylinder to firing, stuff the cylinder full of ¼" rope, do the deed, pull out the rope and move on to the next cyl
ICON Motorsports
1992rs/ss
Jan 31, 2025 05:10 PM
NBrehm
Aug 25, 2015 11:49 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 8, 2015 01:18 AM
