belts squeel at about 3k rpms!!!
Old May 28, 2004 | 07:21 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i just got done putting my car back together. i have had every possible problem but i finally got them all fixed and figured out and now my belts squeel like crazy at about 2500-3k and the more u give it the louder it gets! its drivin me crazy. i cleaned the pulleys with an all purpose cleaner and a nice clean dry rag. all the pulleys line up (had that problem already) and they are good and tight. used a big pry bar to pry them tight and tighten then down. it almost sounds like my fan is hitting something but its not. and i only have 2 belts, power steering and water pump/alternator. alternator is new so dont think i have a bad bearing. i dont know what to do but im goin nuts. and ideas?
Old May 29, 2004 | 01:51 AM
EvilCartman's Avatar
Car: '82 Z28
Probably not enough belt surface contact. I used to have the same problem so made the switch to an electric fan
Old May 29, 2004 | 05:38 AM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
you might have them too tight or loose you might even have to replace the older one
Old May 29, 2004 | 07:12 AM
ede's Avatar
ede
i'd replace them all and see if that fixes it. unless you just bought them it wouldn't hurt changing belts.
eightsixseven
Dec 16, 2024 01:50 PM
xxx3man`
Sep 23, 2015 10:37 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Forced_GTA
Jun 9, 2001 10:49 AM
crazeinc
Sep 28, 2000 11:32 PM
