Motor Mount installation
Old May 30, 2004 | 04:44 AM
JesasaurusRex's Avatar
Trying to take the 3 bolts out that hold the motor mount clam shell deal ontop of the motor mounts. However everytime I try it they only spin in their hole instead of coming out. Can somebody tell me how to do this right?
Old May 30, 2004 | 04:53 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
If I remember correctly there are nuts on inside of the crossmember, I forgot how I got them out but I do remember it was a PITA, I'm sure someone on the bord has a trick to make it eieaser, which will help me when I do my rebuild.
Old May 30, 2004 | 08:21 AM
ljnowell's Avatar
This is gonna sound like a lot all at once, but it will work, and wont take hardly any time at all. Supplies: 15mm swivel socket (or swivel with shallow 15mm on it), about 16 inches of extensions, and possibly a 15mm boxed wrench. Take both front wheels off, and look through the springs with a droplight, and you will see the nuts on the backside. The two top ones can easily be gotten with a swivel socket and the extensions. However, if you are using a swivel with a socket on it (as opposed to a swivel socket) the bottom ones will need the wrench. What i did was put the wrench in a vise, and heat it with a torch. Then I bent it so that when inserted from below, it fit on the nut perfectly. Have a second person hit the top bolts with an imact, and it will be done in less than an hour, no BS. Its not hard, if you do it this way.
Old May 30, 2004 | 11:04 AM
Gonna try it that way thx
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
