HELP...running many codes
Old Mar 27, 2001 | 11:40 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
running codes 22, 32, and 34. I have a new MAF, TPS on there. Started today. Wont idle unless i unplug the MAF and when i do it will save itself instead of just dying. IDEAS? I need the car soon!
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Mar 28, 2001 | 12:29 AM
btt
1989 Firebird
Old Mar 29, 2001 | 11:12 PM
Vader's Avatar
Graeme,
The '22' is a poor connection to the MAT sensor, the '32' is an EGR fault, and teh '34' is a MAF low-flow error. Either you've lost connections to several sensors, of the ECM edge connector is coming loose from the ECM. Check and clean all connections, test the TPS voltage, and clear the error codes (reinitialize the ECM). Report back with results.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
