L98 with a mech fuel pump?
Old May 31, 2004 | 11:44 AM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
1: can i just slap a mechanical fuel pump on an L98? someone told me that the hole for it is blocked off.
2: whats mechanical fuel pump should i get? does a napa one suffice of should i get a holley or edelbrock?
3: do i need to get the pushrod also? or does the fuel pump come with one? cuz the L98 doesn't have one right?
thanks
Old May 31, 2004 | 11:49 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A mechanical pump will never supply the PSI you need for your L98. However, unless you go carb.
Old May 31, 2004 | 11:52 AM
Engine: carbed L98
sorry forgot to mention it's carbed already
Old May 31, 2004 | 12:42 PM
Damon's Avatar
What you need:
1. Fuel Pump. I like the Carter 6 PSI street pump @ 110 GPH, but there are many good aftermarket ones to choose from.
2. Fuel Pump Pushrod. Not supplied with the pump.
3. Fuel pump plate from a carbureted engine. Your stock one is a solid plate with no place for the pump lever arm to stick through inside the engine to contact the pushrod. A carbureted engine plate has an oval-shaped hole in it for the lever arm to stick through but is otherwise identical.
4. two gaskets- one that seals the plate to the block and the other that seals the pump to the plate. The pump-to-plate gasket is typically supplied with the pump. The plate-to-block gasket you can buy separately or just use a thin smear of RTV to seal it up.
Yes, your L-98 roller cam has a fuel pump eccentric to drive the pump and yes, the fuel pump pushrod hole is present in the block. It's basically a bolt-on.
Old May 31, 2004 | 01:50 PM
ljnowell's Avatar
Go buy a stock replacement fuel pump. It will supply more than enough fuel for your engine up to 400hp.
Old May 31, 2004 | 04:43 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I can do a quick look on my block, but I don't think the L98 has the hole casted in it to add a mech fuel pump.
Old May 31, 2004 | 09:29 PM
Engine: carbed L98
yeah let me know
Old May 31, 2004 | 09:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What does the car run on now? Or doesn't it run yet?
Old May 31, 2004 | 11:25 PM
ljnowell's Avatar
Man, I would think that it would. My brother had a '96 350 block, and it still had the mechanical pump hole there, just blocked off.
Old Jun 1, 2004 | 10:59 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, color me wrong, there is a blockoff plate down there.
Old Jun 1, 2004 | 12:13 PM
Engine: carbed L98
so that means no mechanical fuel pump right? damn. i have a blue holley electric pump but the damn thing is so loud i can hear it running inside the car
Old Jun 1, 2004 | 03:05 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
This means you can install a mechanical pump...do as Damon posted above.
Is the only reason you want to switch is because of the noise?
Old Jun 1, 2004 | 06:34 PM
Engine: carbed L98
yeah pretty much. i think it's because there is no return line. a AFPR with return line is like $100
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
