timing
Old May 31, 2004 | 01:51 PM
84_berly_84's Avatar
Car: 84 berlinetta
timing
how do i check to see if my distrubutor is timed to the compression stroke?
Old May 31, 2004 | 02:41 PM
88fbird's Avatar
Car: 84 S-10:(
Pull the #1 spark plug. Put your finger over the hole and turn the crank. When you feel air push your finger off the hole, line up the timing mark on the balancer to the cover.
Old May 31, 2004 | 03:59 PM
ede's Avatar
ede
and after you've done all that check to see that thew rotor is pointing to the #1 post on the distributor
Old May 31, 2004 | 04:50 PM
88fbird's Avatar
Car: 84 S-10:(
I knew I was forgetting something!
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
