QUICK need help with MSD doing right now!!
Old Mar 29, 2001 | 09:40 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
All I need left to do is power lead
it has a power supply all the time?? I asume because it calls to be connected to the batt.
my last question is if there is a power lead going off the batt. stright to the the back of the altinator, I dont see why I cant get my 12v power from there.. would there be a problem with that?????
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel & Oil Press Guage's
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
[This message has been edited by Hecubus (edited March 29, 2001).]
Old Mar 29, 2001 | 10:34 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
anybody have any idea??
have to finish asap
thanks
Hecubus
Old Mar 29, 2001 | 10:50 PM
3.1 firebird's Avatar
not an expert but I dont think it gets power all the time. TRy hooking it up to a 12V source that comes on when the ignition switch is on. Be sure and put a fuse between the power source and ignition box....I;d get black box 1"x1"x1" from radio shack that has 4 or 5 prongs,lettered 37 80, 81 or someletters like that.
Old Mar 29, 2001 | 11:03 PM
I;m trying to think how the little box worked. I think the numbers were 35,85,86,87, but I;m not sure what numbers were ground and what not.
from the battery run a wire to a 20 amp fuse.
from the 20 amp fuse go to a prong on the black box.
from a different prong on the black box run a wire to a keyed 12 v source.
now all of that should take care of 2 of the prongs.
Now from the black box run a wire from one of the remaing of the prongs and ground it.
now take the last prong on the black box and run a wire to the ignition box.
again I dont know exactly what numbers are on the box and which numbers do what, but on the back of the package there is a diagram that shows you what the ground and what you run the power source into, etc.
Old Mar 30, 2001 | 02:07 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
OK I found out that it's bad to connect to the alt.. so I ran to battrey
thanks anyway guys
Hecubus
Old Mar 30, 2001 | 07:50 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I've been running my box to the alt for 2 years now. No problems
Old Mar 30, 2001 | 09:33 AM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
me too. no probs yet.
88 S10
Dropped 3/4
18" Boyd Coddington Timeless 5s
Dart equipped 406
12.20 @ 115.25 mph
Old Mar 30, 2001 | 10:15 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My MSD box gets it's +12 volts from the positive battery cable at the starter solenoid. Of course, my box is closest to the starter, not the battery.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 30, 2001 | 10:19 AM
FastBroker's Avatar
The reason companies ask you to hook it up to the starter is that there will be no corrosion there, as there usually will be on the battery, sooner or later, which can effect the connection.
F-body-fan
Jan 12, 2023 01:49 PM
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
