another valve spring question, part between retainers and springs..
Old Mar 30, 2001 | 10:05 AM
Superblue87Formula's Avatar
On my heads, there are these little "hats" over the valves and the retainers sit on the "hats", with my zz4 cam kit, I have springs and retainers but no hats. Should I re-use the old hats or just stick the retainers right on top of the valve springs???
-=1987 Formula 350=-
Member Greater Cincinnati F-Body Association
Old Mar 30, 2001 | 11:27 AM
ede's Avatar
ede
you don't need them, just the retainer. it'll save you weight in the valve train and give you more spring height. you'd want to make sure you have the correct install height.
ICON Motorsports
1st & 3rd
Old Mar 30, 2001 | 11:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right... those are oil shields. They have been known to wear through and the outside part just fall down around the valve and make noise.
Throw them away and use positive valve seals such as the ones from Crane or Comp if they'll fit, and the retainers without the oil splash shields.
ICON Motorsports
1992 Trans Am
May 10, 2023 07:19 PM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
1nastygta
Aug 8, 2015 07:38 PM
