Stupid Question, But I Need To Know??
Old Mar 30, 2001 | 07:35 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Before it was getting dark I took off my distributor cap to check if anything was out of whack. Well I was putting it back on and on the back turn screw I dropped a small flathead screwdriver down the back of the motor, where it looks like the transmission hooks in. It was now dark and I couldn't get the screwdriver from up top and I didn't want to bother getting a car jack and trying from the bottom. Could this hurt anything, because I have to go to work tomorrow.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old Mar 30, 2001 | 07:38 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
There is nothing it can fall into to cause damage, but it may get stuck between the exhaust and something and melt the plastic handle, or it can fall on the ground and get stuck in a tire. But this is worst case scenario, it will probably just fall out and you never see it again.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 30, 2001 | 07:42 PM
The ODB's Avatar
the screwdriver shouldn't hurt anything as long as you don't end up running over it and stabbing a tire.
the important thing is that the dist cap is back on secured the right way.
Old Mar 30, 2001 | 10:11 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
whoa, wait a minute. i once dropped a screwdriver in the same manner. there was a bolt missing on my tranny dust cover, well the screwdriver just happened to get itself in there and when i started it up the next day WHAM! right thru the floorboard narrowly missing my spleen.
just kidding. i couldnt resist it.
[This message has been edited by bottledpower (edited March 30, 2001).]
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
masonta
Sep 1, 2015 06:40 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
