hard start issues
Old Jun 2, 2004 | 07:54 PM
cougar20th's Avatar
Car: Black 88 Iroc Convertable
hard start issues
im having some trouble starting my car. 88 iroc 305 tpi auto. it doesnt start by just turning the key. i have to let it crank for 5-10 seconds while giving it a quick 1/4 pedal tap. after that you can smell the gas in the exhaust so i know its starting rich. when its cold out the car will start like it should as soon as the key is turned no cranking.
ideas of what to check?
Old Jun 2, 2004 | 08:04 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
coolent temp sensor
Old Jun 2, 2004 | 08:10 PM
cougar20th's Avatar
cool thats what i was leaning towards. ummm where is it located on the motor?
Old Jun 3, 2004 | 03:55 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Depends which motor you have. On the tbi's they are right in the middle of the intake towards the front.
One side note. Theres only one recognized tps signal during startup and thats wot. With the pedal floored the ecm will change the af ratio to about 20:1. Otherwise youll get normal fuel enrichment on startup.
Old Jun 3, 2004 | 08:12 PM
cougar20th's Avatar
i found where it was. replaced the coolant sensor. figured it was $6 so what can i lose. didnt help. any other ideas.
Old Jun 4, 2004 | 02:51 PM
dankhound's Avatar
Car: 91 RS
Try flooring it while your starting it. If it starts right up you probably have a leaky injector.
Old Jun 4, 2004 | 06:34 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Sounds like leaky injectors. Get a fuel pressure gage and monitor your fuel pressure after turning the motor off.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
86Base
Aug 8, 2015 01:34 PM
