cruise control help
Old Jun 3, 2004 | 12:51 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
cruise control help
I'am in the process of installing my supercharger and I need to relocate my cruise control but I can't remember how the vacuum lines go as I took it off awhile ago along with a few other stuff. Right now I'am looking at the cruise unit and I see two spots for lines to go in, one small one and one a little bigger. I found the line for the small one but I have no clue where the bigger one is, any ideas?
Old Jun 3, 2004 | 10:00 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
One line goes to a tank underneath the washer bottle, and I believe had a T in it with another line that ran back towards the firewall Can't remember exactly.
The other ran up behind the plenum to a weird conical shaped T fitting that then went into the rear vacuum port on plenum. The T is to the left and low of distributor cover in pic.
Old Jun 3, 2004 | 10:02 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Then that would go to the port on left in Photo the one on right is fuel pressure regulator, you can see the tip of that conical T in the photo.
Old Jun 3, 2004 | 10:27 AM
Tony89GTA's Avatar
Car: 89 GTA
Ok I think I figured it out, there's a big line that runs along the cruise control wiring that's taped to it, I thought it was for my charcoal canister since I moved it over to that side years ago for my slp cold air kit Thanks for your help.
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
