Car Runs Like Crap
Old Jun 3, 2004 | 12:27 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
Car Runs Like Crap
Took my car out for the 1st time with the new 315HP 355 in it. Holy crap, the original V6 was faster!!! Barely moves, especialy in reverse. Back fires when driving, idles good, but stalls if I rev it. The timing is correct, no doubt about it. Could having no power be because I dont have an exhaust cept for headers (one leaks though) and a y-pipe? No pipping or muffler.
Old Jun 3, 2004 | 01:44 PM
Car: 1988 Camaro
Engine: 350 V-Eight
Now if I rev it up to 4k rpms it makes an extremely loud "pop!" Engine also shakes alot when it idles
Old Jun 3, 2004 | 01:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like you have 2 plug wires swapped.
Old Jun 3, 2004 | 02:09 PM
Car: 1988 Camaro
Engine: 350 V-Eight
Nope...
Old Jun 3, 2004 | 02:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
18436572
Check 5 & 7
Old Jun 3, 2004 | 02:30 PM
Car: 1988 Camaro
Engine: 350 V-Eight
Checked again, aint the wires
Old Jun 3, 2004 | 02:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Lifters too tight, blown head gasket, incorrect assembly.... carb not feeding on one side, rotor / dist cap problem, etc. etc.
Double triple quadruple check everything. If you don't find anything obviously fornicated, do a compression test.
Kind of hard to diagnose much more specifically, my view of it is a bit obstructed.
Old Jun 3, 2004 | 02:47 PM
Car: 1988 Camaro
Engine: 350 V-Eight
I ran the engine on a stand before I put it in, to make sure it was ok. I used a different carb then, and the engine seemed to run fine. Lack of power and poor idle could be caused by the carb. What about the backfiring and a washy clunk sound?
Old Jun 3, 2004 | 03:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Backfiring is often caused by leaning out, which can be the carb. That's why I mentioned one side of the carb not feeding fuel... you'd have half your cyls running EXTREMELY lean. If you've got one you can swap, try substituting it.
Don't know about the sound; that's kind of weird.
Old Jun 3, 2004 | 08:48 PM
Car: 1988 Camaro
Engine: 350 V-Eight
Well, I figured out the wierd sound is part of the exhaust leak. Mabey having no acceleration is because of my gears? 4.03,2.37, so on... there extremely low. But wouldnt that only limit my top speed in each gear? Not how fast it gets there?
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
