edelbrock torquer?
Old Jun 3, 2004 | 07:51 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
edelbrock torquer?
hi guys, its been a while
a friend of mine has a manifold edelbrock torquer for sale, he's using it on his pre-86 block (actually 327) carburated.
i'm thinking to upgrade my 350 from stock aluminium manifold to that torquer manifold, i'd like your oppinion about that manifold, is it better than my stock manifold? would you recomend it?
thanks to all.
Fernando.
Old Jun 3, 2004 | 08:12 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It is really old technology, it's not really worth putting it on. It will probably hurt performance, and gain maybe a little above 5000rpm.
Old Jun 3, 2004 | 09:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Keep in mind that that the Torquer is a single plane intake. With the cam that you listed in your sig, a standard Performer would mst likely be better suited for your engine.
As to the actual quality of the intake itself, some will say its a crappy intake, others (a select few) will say its not that bad. As ME Leigh stated, its an older design. Since its time, runner design has come a long way. Its not even the best in terms of single planes. Like other single planes, it will give a tad on the top end, at the expense of low end torque. It ranks up there with the Weiand X-Celerator intake. Match the intakes 'suggested' RPM to the cam. And the cam in your sig doesnt look anything like a single plane intake-type cam. I'd pass on it.
Old Jun 3, 2004 | 10:25 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you got a cam that will work with its 2500-6500 rpm range and a square-bore (Holley, etc) carb, then its a really nice, streetable single plane. My dad had one on his '73 Z28 and he loved it
Its now waiting to be installed in my '83 when I have a carb for it.
Old Jun 4, 2004 | 07:14 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
thanks guys
then...
the desition is taken, i will not get it, that's it
i'll try the performer or performer RPM (for my cam i think better just performer)
thanks a million guys.
Fernando.
Old Jun 4, 2004 | 11:50 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I'd get a performer RPM. It will work fine for now and you will have room for improvement latter.
FYI the performer is a stock replacement intake manifold.
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
TexasMaro
Sep 15, 2015 06:50 PM
