synthetic oil?
Originally posted by ME Leigh
It doesn't matter.
It doesn't matter.
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
As far as your question is concerned, you can switch to synthetic even if your car has been using conventional oil all its life.
The question of which is better is always being debated here, and you'll never get a definitive answer.
Transmission: 4L80E/4L80E
There is a definate answer, but there are still those stuck back in 60's technology (true duals, ripping out EFI to go to carb, etc.).
There are two "issues" with high mileage engines: 1) how much wear has occurred, and 2) how much sludge and varnish has been built up by the use of petroleum oil.
Those were also the issues back when I started using synthetics back in 1983.
#1 is only an issue with oil leakage or consumption. If you don't mind adding another quart every 800 miles at $5 a pop, synthetic is going to reduce further wear. I stick to recommending it for "mechanically sound" engines only.
#2 can be handled in a couple of different way: By a crankcase flush - AMSOIL has had an excellant one available since 1983; or by gradually changing over to synthetic - using one quart of synthetic and the rest petroleum at the first oil change, 2 qts syn the rest syn at the next, and so on until the entire fill is synthetic, changing the filter each time, of course.
Fair warning: A synthetic is not a synthetic is not a synthetic. Stick to the premium offerings (AMSOIL, Mobil 1, Red Line, Royal Purple) and avoid the "me-too" offerings of the others which use an inferior base lubricant that has only been allowed to be called a synthetic by the actions of lawyers and judges.
Since, as stated, this comes up all the time, do a search and sit down for awhile and read, read, read. Just don't believe everything you read ("I used synthetic once and my engine leaked for the first time ever.", etc.).
To preclude more and more of the same, we'll say "Good night, Gracie" to this particular thread.
Oh, about that 60's technology stuff: How many of you are still using bias ply tires? Even drag racing tires are going radial these days.
skinny z
Oct 5, 2015 06:23 PM
