need advise on 327 proyect
Old Mar 31, 2001 | 09:58 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
yes, it's not intended as a race engine, maybe to kick few muswang butt once in a while, the block will be .030 over but the heads will be 416 (58cc from 305 HO) it's intake valves are bigger than those that were on the original heads, compression it's gonna rise like hell but i want to use reg pump gas the question is...
what kind of pistons and cam do i need to achieve this?
LOW budget to be consider.
thanks to everybody....fern.
third gen muscle power is the only thing that can match the power of flight...
Old Mar 31, 2001 | 11:07 AM
ede's Avatar
ede
without doing the math to figure compression i'd say you need a dished piston. you aren't very clear on what the engine is, or what it's in, efi, carb, intake, headers, auto or manual so picking a cam would be a joke without knowing more.
ICON Motorsports
1st & 3rd
Old Mar 31, 2001 | 03:25 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
ok. it's a 327 bored .030, will go with a 350 corvette (79?) aluminium manifold, rochester 4-bbl carb.
doing some math i've got to the conclusion that with flat top pistons and a regular head gasket (big one) should have 9.7:1 compression. (58cc heads)
fern.
Old Mar 31, 2001 | 06:17 PM
ede's Avatar
ede
i've used lunati bracket master cams in similar SBCs. don't have a catalog handy but the one with .480 lift ought to work good for you. every one else here will tell you to run comp, but i like lunati.
ICON Motorsports
1st & 3rd
Old Mar 31, 2001 | 06:23 PM
The ODB's Avatar
I would just take a grinder and unshroud the combustion chambers around the valves, then just use flattop pistons.
Old Apr 1, 2001 | 05:57 PM
GOLD85's Avatar
i wouldn,t use 305 heads they suck. find some open chamber early 70s heads with 1.94s and 1.5s vlaves, they will out flow punched out 305 heads any day.
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
Elephantismo
Feb 13, 2019 12:51 AM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
84 TA NV
Sep 6, 2015 08:02 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Mickeyruder
Sep 2, 2015 02:45 PM
