Engine Temperature
Old Jun 6, 2004 | 07:47 PM
berklified's Avatar
Engine Temperature
What is the average running temp for an 87 5.7L 350, NOT INJECTION, edelbrock carb. it has the standard '87 water pump.
also, this squeeling noise just started, it's coming from the pulley area, and it's really loud then when i start to idle it slows and then MOST, not all of the time it stops. What is this noise? could it be the water pump? even though it's definetly still pumping?
Berkley
Old Jun 6, 2004 | 09:02 PM
Vader's Avatar
That depends upon the ambient temperature, but in your locale, the coolant temperature should maintain between 100° and 105°C, on a stock setup.
Old Jun 6, 2004 | 10:03 PM
BWW's Avatar
BWW
i would think your temp would be between 190-220 F and the sqeualing noise is almost certainly your belt slipping. check the tensioner or change the belt
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
