All of a sudden - no spark. What gives?
Car: '99 HO Z28 / '03 Trailblazer
I last drove the car about 6 weeks ago. About 3 weeks ago I tried to start the car and the battery was dead. I replaced the battery with an Optima red top. Car cranks, but no start.
It's an ex-LG4 carbed car that has a 350 shortblock under it. I checked and it's getting fuel. I pulled a plug, and it doesn't appear to be getting juice. I rested it first on the painted valve cover (duh) then on the exhaust manifold...same result both times.
Can an ignition coil just 'go out'? I noticed no degradation in performance the last time I drove it.
I still need to check the ground strap to make sure it hasn't come loose/broken. Anything else I should check? I've only owned the car a couple months and driven it about 4 times total so it's history is unknown.
Transmission: 4L80E/4L80E
Check for condensation under the cap first. But it is possible for the coil and control module to "just go out".
I will check for the condensation too since it seems that rear hood seal leaks for some reason and water builds up on top of the air cleaner.
RedLeader289
May 28, 2019 01:47 PM
