Oil pan differences
Old Jun 9, 2004 | 09:30 AM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Oil pan differences
What is the difference between the oil pans for 1979 and before blocks compared to the 80-85 blocks? Do they bolt up the same? Is it just the dipstick that is different on it? I am using a '76 truck block and am trying to keep the passenger side dipstick. So i guess my question is, will an 80 - 85 passenger side dipstick oil pan fit on a 76 350 block?
Old Jun 9, 2004 | 01:55 PM
Damon's Avatar
All the motors I have built you would think I'd know the answer. I don't, really. Hope the following helps anyway.
I have a 1978 305 with a passenger side dipstick and the dipstick connected directly to the pass side of the OIL PAN, not through the block in any way. When I used the pan later on a 350 motor of similar vintage I removed the dipstick from the pan, welded the hole closed and just shoved in a block-mounted driver's side dipstick into the 350 block on the driver's side, which was the style of dipstick this common 350 block used originally.
The 78 passenger-side dipstick pan still had the little cut-out on the driver's side of the pan that worked with the more traditional driver's side block-mounted dipstick. Aside from welding the original pass. side dipstick tube hole closed, it was a bolt-on.
The vast majority or earlier motors I have used have taken a block mounted driver's side dipstick. They kind you can buy for $10 off the "chrome parts" aisle at Pep Boys.
Old Jun 9, 2004 | 03:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. A pass side pan will not work on a driver-side block, or vice-versa. The pan has a little place where it loops out about an inch to include the dip stick.
Old Jun 9, 2004 | 10:53 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Alright, thanks guys.
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
