help removing camshaft
Old Jun 9, 2004 | 02:20 PM
dp149's Avatar
1985 LG4...tearing down and I am trying to remove camshaft but if looks like there is a little lifter like item that moves in and out near the front of the camshaft. Thus when I try to take the camshaft out it binds to it..all the lifters are out and I can't even see another access point to get to this...If I try to push it all the way in it won't go far enough back to remove...
what is this and how do I get it out for camshaft removal? hope I explained this ok............
Old Jun 9, 2004 | 02:29 PM
ede's Avatar
ede
fuel pump rod, remove the fuel pump
Old Jun 9, 2004 | 09:35 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yep, thats the fuel pump pushrod for the mechanical fuel pump. You have to unbolt the fuel pump to drop the pushrod out of the way.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
