Car runnig like crap???
Old Jun 9, 2004 | 09:09 PM
IROCBlueZ28's Avatar
Just like the post says! I noticed that my car did not want to start this mornning? my car normally is a turn key, varoom, purr's like a kitten. today, I went to start it up and I had to feather the throttle to get it running? Then it ran like crap ever since? ..... After i put my foot on the gas, it finally held an idle. When I put it in dirve, it wanted to die! As I accelerated slowly, it ran like it was missing a few cylinders or as if some of the plugs were fouled? So I changed the plugs, checked the wires, NOTTA? Set timming to 10deg advanced, nothing. I did get a code 33 so I changed my map sensor, but nothing changed???
Any help would be greatly appricated!
Old Jun 9, 2004 | 09:14 PM
BadIroc's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 Crate Motor Holley Stealth Ram
Transmission: WC T-5
mabye a glogged fuel filter?....check ur PCV as well......your fuel pump could be taking a sh*t as well
Old Jun 9, 2004 | 09:15 PM
05kcilS's Avatar
Car: 1991 Z28
Engine: 350 L98
i got some bad gas teh other day... it made me want to sell my car. the next morning... for some reason it ran perfect . :shrug:
hope that helps.
Old Jun 9, 2004 | 09:26 PM
I replaced the fuel filter and pump last year I forgot to add, under part throttle acceleration, it seems to surge like it's not running on all cylinders? But wot, it is ok, or at least it seems to be ok?
Old Jun 9, 2004 | 09:31 PM
BadIroc's Avatar
your not getting any other codes???? even when it starts acting up??? try doing a compression check......also like someone said above, you might have gotten some bad gas
Old Jun 9, 2004 | 10:32 PM
nope, I am at 1/2 tank. How else would you find out if it was bad gas? I forgot to add, ever since this am, when the car started not wanting to idle, i have been seeing a light next to teh check engine is a light that is red stating "infl rest" which I think is the air bag sensor? I hate this car! help please!
Old Jun 9, 2004 | 10:40 PM
BadIroc's Avatar
hmm assuming ur car is a 90 and up.....i dont know man i got an 88 and i have no clue what that light means i dont even have one...
Old Jun 9, 2004 | 11:09 PM
Thanx for trying! nice roc by the way! My car seems to not want to start unless i put my foot on the throttle. I normally can just turn the key with out putting my foot on the throttle and she fires up right away? Now, I have to put my foot on the gas pedal to get it fired up and it runs like crap?
Otherwords, hard starting it! I have to feather the throttle to get it going. Then it runs like it's missing or somthing
Old Jun 10, 2004 | 09:59 AM
OK, I have fuel comming from my AFPR. I think I found the problem
9192camaro
16
Feb 3, 2019 12:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
