car cutting out at 5000rpm part 2
Old Apr 3, 2001 | 10:09 PM
bad camaro RS's Avatar
ok ive check my msd ,my wires,plugs,coil all good only thing i can find wrong is 02 sensor goes from ready to not ready "on my auto xray could that some how be my prob? ill go from closed loop to open loop and o2 stops reading "ready" i think i need a heated o2 but could this be related to my cutting out i have a 87 355 tpi maf system thanks
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old Apr 3, 2001 | 11:50 PM
The ODB's Avatar
check your valve adjustment and springs.
Old Apr 3, 2001 | 11:59 PM
theformula's Avatar
whats your knock retard at 5000rpms? I find mine is the highest at 5k.
Does your fuel pressure increase past 5k or drop?
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Apr 4, 2001 | 07:18 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Check to make sure you wired the coil right. If you reversed the polarity it will run, but loose the top end.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1nastygta
Aug 8, 2015 07:38 PM
