Timing
Old Jun 12, 2004 | 05:16 PM
stevecvash's Avatar
Car: 85' Camaro Sport Coupe
Engine: 1970 LT1
Transmission: 700-R4
Axle/Gears: 3.23 Posi
Timing
I've got my engine at top dead center and the only place my rotor will fit all the way down is tward the firewall. Is this right? here is a pic
Old Jun 12, 2004 | 05:21 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Looks pretty close to mine. I had to even take the cap off when i took out the tranny so it wouldn't bust.
Old Jun 12, 2004 | 06:09 PM
ss85tadude's Avatar
Car: 85 Trans Am
So is this correct? Can I put it all together and start it?
Old Jun 12, 2004 | 07:27 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If the engine is at No.1 TDC, and you start your 18436572 with the terminal that the rotor is pointing to right now as 1, everything will work fine... However, it will be a lot easier if you drop the distributor in 180 from there (with #1 pointing slightly to the driver side of center towards the front). You may have to turn the oil pump slightly depending, but it can be done with a long screw driver and some patience.
Old Jun 12, 2004 | 08:14 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would pull the dizzy and re-seat it. It looks like you are at #6 TDC which isn't a big deal but I always like to start at #1 TDC.
Old Jun 12, 2004 | 10:15 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If you want to be lazy you can just drop it in and turn the motor by hand/bump with the starter untill it lines up with the pump and drops in by itself.
Old Jun 12, 2004 | 11:49 PM
vampiroc's Avatar
Car: Z28
Re: Timing
if that's TDC for cylinder 1 then you are 180 off. just lift the dizzy out a bit, turn it 180* then drop it back in. it'll seat in place just fine.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
