Figuring Compression not what they should be
Old Jun 13, 2004 | 01:58 AM
1993GMCPU's Avatar
Car: TBI CHEVY, TPI 5.0 HO
Engine: 5.7 FIRST hp SMALL BLOCK, BIG BLOCKS!
I have a 350, Bored 40, H345NP40 HYP Federal Mogue Pistons, SR Pro Topline (have 2.02-1.60s but not using them no valves etc) heads are 76 cc with .020 shaved off heads and thinner gasket, .015 Fel Pro 1094) for better quench, 40 vs 60+, 1.94-1.50 Valves, Cam 212-215 @50, 444 Lift with out allowing for 1.6 Comp Cam.
What do you need to figure Actuale compression
Old Jun 13, 2004 | 05:57 AM
ede's Avatar
ede
https://www.thirdgen.org/techbb2/sho...on+calculation
Old Jun 13, 2004 | 07:09 AM
1993GMCPU's Avatar
How do I get other things like cylinder displacement etc:
Specifications:
* Bore: 4.040 in.
* Stroke: 3.480 in.
* Rod length: 5.700 in.
* Compression ratio: 10.01:1 (58cc heads), 9.39:1 (64cc heads), 9.02:1 (68cc heads), 8.68:1 (72cc heads), 8.37:1 (76cc heads),
* Head type: Flattop with 4 valve reliefs
* Oversize: .040 in.
* Ring size: 5/64 in. top ring, 5/64 in. second ring, 3/16 in. oil control ring
* Weight: 595 grams
It's cylinder displacement + piston dish (or - for domes) + gasket volume + piston deck height volume + combustion chamber volume
divided by.....
piston dish (or - for domes) + gasket volume + piston deck height volume + combustion chamber volume.
Old Jun 13, 2004 | 03:05 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Figuring Compression not what they should be
You need to measure the volume of the combustion chamber on your heads. its not hard to do.
You need to measure the piston deck clearance at TDC on your assembled motor. Also not hard to do.
the nominal deck clearance for those pistons in a non decked stock block is .045". Yours may be more or less.
.055" below deck at TDC is not unusual.
The volume of the piston valve reliefs is 5cc's.
The volume of a .015" thick shim type gasket is 3.5cc.
the gasket bore size is 4.10", the thickness is .015"
you can GO HERE
and find the engine cr calc and punch in the numbers to find your cr.
Going to be just over 9:1.
Old Jun 13, 2004 | 11:14 PM
1993GMCPU's Avatar
I appreciate that a lot, thanks, so it's in area we wanted which is above 9.0, except not sure what SR is yet.
40 over motor should be ok and smaller valves I had hoped would match smaller Factory style TBI we are going back to all factory except cam even though I like 212 LSA I seen and if I get better like to try one of Summits. Present cam has a 212-218 Duration 444 Lift cam sort of short on lift?
Well 1.6 Rollers helped as I was hoping to get around 266-224 @ 50 durations and only wished I gotten more lift on exh. Hope motor runs and no more setting around!
:lala:
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
customblackbird
Oct 1, 2015 04:30 PM
84redta
Sep 19, 2015 09:58 AM
Fronzizzle
Sep 8, 2015 12:10 PM
