motor mount nuts,,,,,,how were yours?
Old Jun 13, 2004 | 10:53 PM
eddie jr's Avatar
So I did a lot of searching about motor mounts and found out what a pain it is. I peeked under today and saw the nuts in the crossmember but they looked quite rusty. Just wondering if they will even come off, nevermind the awkward position.
Just wondering how bad everyone elses looked. where they pretty gross looking to but the nuts still came off??? The last thing I want to do is snap one in there
Old Jun 13, 2004 | 11:02 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you mean on the block or on the crossmember?
Old Jun 13, 2004 | 11:14 PM
eddie jr's Avatar
On the cross member. The nutson the bottom (in the crossmember) on the back of the bolts
Old Jun 14, 2004 | 12:33 AM
3gc's Avatar
3gc
Car: Z28
Snapping them would be no big deal, the bolt will just come out if you snap it. I've done it on two camaros and didn't have trouble. I forget if they were rusty though, i think they were covered in grease actually.
Old Jun 14, 2004 | 01:50 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
yes highly recommend you replace them with some grade-8 material. personally I used grade-10. Small price to pay for what holds your motor up.
Old Jun 14, 2004 | 02:56 AM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
Transmission: TH700 R4
Axle/Gears: 3.08 drum
I found them to be easy to get to by using a 15 mm box wrench bent at a 90 degree angle inside the crossmember
Old Jun 14, 2004 | 04:36 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
Now I know what size to bend.. Thanks!!!
Old Jun 14, 2004 | 12:35 PM
3gc's Avatar
3gc
Car: Z28
I took my springs out both times, figured i'll spend a little extra time to save myself a headache.
Old Jun 14, 2004 | 04:10 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
I gotta do something with these cheap wrenches.. I'd never do it to one of my good ones..
Old Jun 14, 2004 | 04:43 PM
eddie jr's Avatar
So they aren't threaded through those holes in addition to the nut holding them on (they will just pop out?)? Just curious cuz the holes nearby for other mounting locations looked small.
Old Jun 14, 2004 | 08:04 PM
3gc's Avatar
3gc
Car: Z28
Yep, no threads on the engine crossmember for the motor mounts. Bolts slip in.
Old Jun 14, 2004 | 09:23 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I love when bolts like that sheer apart... Its those rusty sway bar link bolts that won't give up (and others like them) that are a real pain..
Old Jun 15, 2004 | 12:32 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
yeah, with sway bar links i've just taken a dremel to them
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
E Rod
Aug 28, 2015 05:17 AM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
