Right Cam for my car
Old Apr 4, 2001 | 02:49 PM
Wheres Axl Rose's Avatar
Hey Guys, Stupid User time....
I've been throwing around the idea of replacing my cam, so I need some basic info...
My Car is a 92 RS, so it has the 305 TBI setup, single cat, so on...
What cam is in my car now? What would be a good replacement cam for my car? I havent done any mods as of now, but i plan some in the future. Should I wait until I do the other mods first? In fact, when should you upgrade the cam?
I have no real knowledge about this sort of thing, and need some advice.
Thanks,
Chris
[This message has been edited by Wheres Axl Rose (edited April 04, 2001).]
Old Apr 4, 2001 | 04:50 PM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
TBI cars cannot run a whole lot of cam without running into computer problems. I would suggest this comp grind, or something similar... 210/220 duration at .50 with .500/.510 lift, this is a hydraulic roller grind, and you will need better valve springs. Crane makes some that will handle up to .600 lift and have the right pressure for around $90. good luck
Black 89 IROC...Mods: 355, 10.5:1 comp, Big Solid Crower Cam, TFS heads, Victor Jr, Holley, and a 5 spd...12.90 @ 112.5 with a 2.3 60ft time on BFG radial TA's
Old Apr 4, 2001 | 06:58 PM
Violate 3.8's Avatar
a lot of TBI guys are running LT1 cams with success, check thier board.
Old Apr 4, 2001 | 09:55 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
one nice choice would be slp51002, but deffinitly not over a .500 lift cam. preferrably less than 220@.050 duration. you should be able to reuse the lifters, but will want to replace the timing chain. chip will also be a good thing to replace at this point.
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Fronzizzle
Aug 9, 2015 01:15 PM
anesthes
Aug 8, 2015 09:37 PM
