Timing tips.
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
Timing tips.
Anyone have any tips for adjusting timing? I changed distributor caps and the distributor was loose. Now I need to adjust/set the timing and was wondering if there are any tricks to make it easier.
You need a timing light disconect the 4 wire connector on the distributer or the brown wire under the pas side carpet. then set it according to the sticker on the fan shroud. sould be 6d but it could be different so check the sticker.
