What about AFRs and Edelbrock headers?
Car: 91 camaro
Engine: 383
Edelbrock TES and AFR 190s: is anyone using this combination, and did you run into any problems? Which spark plug angle did you use, the L98 or the regular angled? How about The Edelbrock Performer heads? They only come with a straight plug, will this work?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Problems? Yah, the Edelbrock headers dont flow as well as the AFR heads, choking off your exhaust.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: Death Mobile
Engine: 666 c.i.
According to a recent "build up" of a 350 by Chevy High Performance the difference between 1 5/8" headers and 1 3/4" headers at the 400 HP level made a 7 HP difference. And various other tests I have seen have shown similar results. It's not until you get into high 400 HP levels that smaller headers become a restriction.
If you already own TES, I wouldn't waste my money getting 1 3/4" headers unless you are going well over 400 HP. That's a lot of money to spend for an extra 7 HP. You should probably also have a 3 1/2" exhaust system also to get the full benefit.
If you don't have headers and think you may go to those levels then get the larger headers. Larger headers are better for higher rpms and smaller headers for lower bottom end torque.
Hotrodboba400
Dec 10, 2019 07:07 PM
355tpipickup
Sep 13, 2015 11:35 PM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
