Distributor Problem perhaps ? pls help down to the line...
Old Apr 4, 2001 | 01:13 AM
Bort62's Avatar
Fixed the Vac leak, But It still Wont Idle in Gear.
I got out the Timing light and Discoverd that when I set inital to 8* or So at 1000 Rpm at idle in park, When I rev the Motor, and centrifugal Kicks In, the advance kciks up appropriately, but when it comes down it only comes down to about 12* or mroe and stays there, Idle goes up accordingly as well. Then I time it back to 8* And it does it all again...
This is all with the Vac advance Disconnected. Im thinking perhaps the centrifugal advance mechanism is sticking ? I took it all apart and it dosent appear to be However, uugh...
It idles very nicely in park at 1000 rpm at 8* advance but as soon as you touch the gas, it hops up. As soon as you put it into gear it sputters out and dies, any ideas ?
Its a Lg4 w/ Copmp 981 valve springs, Comp Timing Chain, Comp XE262H And performer RPM intake. Valve Lash seems to be Set appropriately. There is One a little loose that is Ticking, but that shure shouldnt cause any of the described problems.
Its a Vaccum advance dist out of a 79 firebird I had, And a mech Qjet from an older truck. both worked Fine Before I swapped The cam and intake.
I have Driven it With this setup By revving it up a bit and getting it into gear, And it seems to drive fairly well, But still likes to die At idle in gear, Have to pop it into neutral at stoplights.
Ive already had to borrow a buddy's car For 2 days Now, And I really need to Get my Game back On the Road, any help is appriciated
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Apr 4, 2001 | 02:39 PM
Bort62's Avatar
BTT please, this is a lil important
Old Apr 4, 2001 | 03:13 PM
87Z-ya's Avatar
remanned hei's are so cheap I would just replace it. It sounds like there is a problem with the mech. advance.
87z 383,afr 190's, comp hyd roller(242/248-.540/.562,114 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, tremec 5spd, , 1,3/4" slp headers, speed pro bank to bank-wb02.
"Just remember children, no man can beat you once youv'e found the cliterous." 'chef'
Old Apr 4, 2001 | 11:20 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I agree , sounds like the mech. advance is sticking.
Turn the rotor clockwise against the springs and let go. See where it returns to. Now try turning it further counterclockwise and see if it was returning all the way.
^^^^^^(did that make any sense??) ^^^^^^
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Apr 5, 2001 | 10:49 AM
Bort62's Avatar
Yeah Engineboy, I took it out and cleand it up a bit, and it runs !: )
Just need to get the timing dialed down and go wake up the neighborhood, It is LOUD now! hahaha
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
