Finally fixed intermittant no start problem
Old Apr 4, 2001 | 11:08 AM
JWS's Avatar
JWS
When my motor would get above 190, if I shut it down and waited a few minutes, it wouldn't start until it cooled back down again. No click, nothing would happen unless I let it sit and cool down or jumped the starter solenoid. It ended up being a relay that sends voltage from the ignition switch to the P/N safety switch. The relay is mounted under the kick panel near the hood release handle. I remember a few other people posting that they had the same problem and couldn't figure it out, so hope this helps.
Joe
89 IROC 5.7L
Old Apr 4, 2001 | 11:35 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Damn... thanks. That might be my problem, as well. I'm one of the ones you mentioned having had that same problem. I bought a remote location solenoid (haven't installed it yet), but probably won't put it in til a later date. How did you find out it was that relay? Any idea if 91's are the same location? Thanks...
KAM
Old Apr 5, 2001 | 10:55 AM
JWS's Avatar
JWS
I had my multimeter with me one of the times it did it, and before-hand I unbolted the shifter console cover, so I could easily probe the P/N switch while I turned the key. I found out that the green wire with a white stripe was not getting any voltage, so I traced it over to the relay, wich was getting voltage when I turned the key to crank, but the green/white wire was not registering voltage. It's only a 10 dollar relay at Pep Boys, and I would guess it's in the same location for the 91's.
Joe
89 IROC 5.7L
92camaroJoe
Jul 29, 2023 07:57 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
