Distributer gear question
Old Jun 15, 2004 | 12:14 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
motor is an 87 305 motor with hydraulic-roller cam.
I installed a new Crane cam about 2 1/2 years ago along with a bronze gear which I thought I would need. Well the bronze gear has been chewed slightly and is throwing my timing out. It's inface screwed up completley.
I ordered a new bronze gear today .490" shaft (I presume this is the correct size?). However, after doing a search I found this link:
http://www.chevyhiperformance.com/te...ler/index.html
In the article they say that
"Virtually all street hydraulic- and mechanical-roller cams now come from the major cam companies with iron gears pressed onto the end of the camshaft to allow the use of stock-type iron distributor gears instead of the softer and less durable silicon-bronze gears. "
Well I never knew this. So the cam I have I could just put on the original gear and not have to wory about screwing the cam up?
Any info on this is appreciated. Did I at least order the correct shaft size gear?
Robert
Old Jun 15, 2004 | 12:22 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
I just called Crane because this was playing on my mind. I don't theed the bronze gear. Damnit!! I just bought another of those too. I'll have to see if they will give me a refund.
So what would cause the bronze gear to wear? This is what I'm now trying to establish.
Thanks again
Robert
Old Jun 15, 2004 | 12:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They always wear. That's their job. They're sacrificial.
Just use a factory austempered ("melonized") gear. It will last the life of the rest of the motor.
Old Jun 15, 2004 | 12:25 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thanks for that. I've already dug the original factory one out. I'll fit it tomorrow.
So how long have they been pressing iron gears onto the hydraulic cams? I was always under the impression you needed bronze gears.
junkcltr
Aug 2, 2019 11:12 PM
Infested
May 22, 2018 11:56 PM
Brcharrelson
Aug 26, 2015 07:47 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
