installing cam
Old Jun 16, 2004 | 12:03 AM
88Z's Avatar
88Z
Car: 88 Iroc
installing cam
I'll be installing a cam really soon into a completely stock L98 with 90,000 miles. Besides springs and studs, what are some essentials that i should replace? Keep in mind that I'm on such an extreme budget, i'm practically sellin my body for every cent i get.
Old Jun 16, 2004 | 02:17 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
New timing set wouldnt be a bad idea. Probably also a good idea to get a good set of rockers to go along with it. Also replace the lifters if theyre in poor shape.
Old Jun 16, 2004 | 02:26 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Inspect the lifters. Feel each one for any oddities. Primarily spin the roller. If they spin freely, they can be reused. Otherwise, they are a cheap and easy junkyard score.
But yep, i would swap the timing set. For rockers, i would recommend the Comp Magnum series. They are the steel rollertip versions and cost roughly $150 for either 1.52 or 1.6 non self aligning. I believe it is $195 or so for the S/A versions.
Old Jun 16, 2004 | 02:28 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Do the comp. mags clear the later style valve covers?
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
*OOPS
Old Jun 16, 2004 | 02:29 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
OH thats right, you would need the self aligning versions. The 1.52 may clear height wise. the 1.6 MAY require tall VC's. But yes, Comp does offer centerbolt rockers. I believe the P/N is 1416-16 or something like that. I have them on the Vortecs and they work fine but i have tall covers.
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
