valve spring size
Old Jun 15, 2004 | 02:40 AM
88Z's Avatar
88Z
Car: 88 Iroc
valve spring size
What are the dimensions of the largest valve springs you could use with stock, 083 L98 heads without having to machine the heads?
Old Jun 15, 2004 | 02:46 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
without having to machine the heads, 1.26" OD generally.
Old Jun 15, 2004 | 04:36 AM
ede's Avatar
ede
besides the spring diameter you need to watch going over .47 or so lift with pull out studs.
Old Jun 15, 2004 | 11:20 AM
88Z's Avatar
88Z
Car: 88 Iroc
So you're saying that i wouldn't be able to use a cam with .487 lift and .500 capable springs?
Old Jun 15, 2004 | 11:32 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
You can, it's just that the factory rocker studs (pull out studs as we like to call them) aren't the most reliable thing when lift over around .480" is used.
Old Jun 15, 2004 | 12:42 PM
ede's Avatar
ede
i wouldn't run any thing but a stock cam and springs with pull out studs
Old Jun 15, 2004 | 11:48 PM
88Z's Avatar
88Z
Car: 88 Iroc
OK, let's say i get some 3/8 screw in studs, then how much lift is possible???
Old Jun 16, 2004 | 12:18 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Screw in studs are not really limited to max lift and what not like pressed in studs. Once installed, don't worry about them. You will be fine assuming you don't go runnning off and installing some .700" lift drag cam.
Old Jun 16, 2004 | 12:20 AM
88Z's Avatar
88Z
Car: 88 Iroc
then how much lift can you have without machining the heads? i was told it was about .525
Old Jun 16, 2004 | 04:17 AM
ede's Avatar
ede
machining the heads for what? i run screw in studs with any preformance cam. .5 lift is about the limit of stock diameter springs.
deracer
Apr 11, 2016 12:04 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
