Gas Gauge Freezes
Old Jun 16, 2004 | 12:15 AM
89IROCCVRT's Avatar
Car: '81 Camaro (Modded), '89 IROC cvrt (Stock), '00 GMC Jimmy
Engine: Modded 350 in '81, 305 TPI in '89 IROC, V6 Vortech in GMC
Transmission: T-350 in '81, 700-R4 in IROC
Gas Gauge Freezes
Occasionally, my gas gauge will freeze and I'm wondering if maybe the grounds need to be cleaned at the tank at behind the dashboard. If so, where is the ground at the tank located?
Old Jun 16, 2004 | 08:44 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It grounds to the floor pan under the carpet near the front of the drivers seat.
Old Jun 16, 2004 | 08:49 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
possibly could be a sticky float in the tank also
Old Jun 16, 2004 | 08:58 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey thegeneral,
That is true but I don't think that is an option he wants to hear. It could also be a bad gauge in the cluster or bad connectors on the gauge. Try this chart.
Old Jun 16, 2004 | 09:13 AM
89IROCCVRT's Avatar
thanks for the help, i'll try that right away.......ones things for sure, the guys at this forums know their stuff (with the exception of me haha)
Old Jun 16, 2004 | 09:48 AM
THEGENERAL's Avatar
thats what these forums are for to help out those in need
Old Jun 16, 2004 | 10:46 AM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
OR, perhaps you're just to easy on the gaspedal...
Say trickster, since you seem to know so much about electrics for our cars, do you know where I could get a tempswitch connector, possibly with a bit wire on it?
Old Jun 16, 2004 | 11:15 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you talking about the connector for the Coolant temp sender for the gauges?
Old Jun 16, 2004 | 11:20 AM
tilstad's Avatar
No, the one that turns on my fan that wont go...
Old Jun 16, 2004 | 11:22 AM
tilstad's Avatar
The connector for this one. Have been through a couple of sites already, ac delco, even my dealer. It wont do with a universal connector either. My old one just cracked to pieces.
Old Jun 16, 2004 | 11:38 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay,
They have been discontinued by GM as has most of the wiring harness and connectors. I can still find them in junkyards around here, unfortunately that is not a viable solution for you in Norway. You could try calling or e-mailing Hawkes at thirdgenparts.com and see if they can fix you up.
Ghettobird52
Jul 5, 2024 11:18 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
