Assure proper crankshaft clearance for a drain plug?
Old Jun 16, 2004 | 02:24 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
At Autozone I was told this magnetic drain plug will work for my car. MOTORMITE OIL DRAIN PLUG
On the website it says assure proper Crankshaft Clearence.
The guy at the store couldn't help me much. How would I do this?
Old Jun 16, 2004 | 02:32 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Hmm that must be one really big plug if theres a chance it may hit the crank. You can stick something in the drain oil that will go in as far as the plug would. Then crank the engine over by hand and see if it hits.
Old Jun 16, 2004 | 02:34 PM
dankhound's Avatar
Car: 91 RS
I just realized this is the second question youve asked about a magnetic drain plug and theres an easier solution than buying one. If you rub a magnet on the drain plug you have it will become magnetized. Problem solved.
Old Jun 16, 2004 | 02:44 PM
Damon's Avatar
The drain plug on a SBC V8 is easily 3" from the nearest part of the crankshaft. If it screws in and seals up it'll work just fine.
Cleotiz
Jan 6, 2018 08:56 PM
gixxer92
Sep 1, 2015 04:32 PM
Justin92GTA
Aug 27, 2015 11:16 PM
LT1Formula
Aug 20, 2015 09:36 PM
djmarch
Aug 9, 2015 05:27 PM
