Roller Cam?
Old Jun 17, 2004 | 09:45 PM
Frank_Blotto's Avatar
Car: 87 Camaro Z28
Engine: LG4, CCC
Roller Cam?
What is the best way to tell if you have a roller cam? I have my valve covers off already, so my guess would be to peek down at the lifters, but I don't know what I'm looking for. Thanks.
Old Jun 17, 2004 | 09:47 PM
Formula305FI's Avatar
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
take intake manifold off if u have a spider web holder looking thing its roller. easy enough
Old Jun 17, 2004 | 09:53 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Hehe...that would most likely be teh easier way, except that I have no real desire to take my intake manifold off at the moment... any other way?
Old Jun 17, 2004 | 10:22 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Well if you have a 1987 car, with the factory motor, you have a hydraulic roller cam.
Oh yeah, an easy way to check would be to compare one of your pushrods to a flat tappet cammed motor. Your pushrods will be consideribly shorter.
Old Jun 17, 2004 | 11:26 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I think his sig says he has a carbed LG4 or some such. I don't think those were roller motors. I think only the TPI motors had rollers. He'd need an LB9 or better to have a roller.
Old Jun 17, 2004 | 11:27 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yep, you can measure the pushrods if you'd like. hydra. roller will have roughly 7.3" pushrods whereas hydra. flat tappet will be 7.8"
Engine RPO does not designate roller block. Year does. Pre-86 was flat tappet, post-87 was factory roller, at least in passenger vehicles. I do not believe trucks got rollers until the Vortec in 96.
Old Jun 17, 2004 | 11:41 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Genius i would have never thought of that! The 87 LG4 came with a roller cam IIRC, even though it was the base motor.
Old Jun 18, 2004 | 12:56 AM
Car: 87 Camaro Z28
Engine: LG4, CCC
Good plan. Measured the pushroods, its a roller. Yay. Thanks
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
