Squealing Clutch Pedal
Old Jun 18, 2004 | 12:59 PM
sephiroth99's Avatar
Car: 86 z28
Transmission: t-5 original
hi I got a problem with my clutch pedal as the topic says it squeals whenever I engage the clutch. I got under the dash to see whereabouts it was coming from and it sounds like it's coming from where the rod for the pedal meets the firewall. There is a little plastic cover over the section where the rod goes into the firewall. Anyone know how i could go about remedying this problem, maybe with a little grease or something? If i need to grease it, which grease would be recommended. Thanks
Old Jun 18, 2004 | 01:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Does it squeal if you hold it down, or just squeak while its moving up or down?
Old Jun 18, 2004 | 01:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's no "cover" there, the rod goes straight into the master cyl.
Sounds like you're about to need a hydraulic set.
Old Jun 18, 2004 | 04:50 PM
Car: 86 z28
it only squeals while im pushing it in.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
