valve guide seals
Old Apr 5, 2001 | 10:29 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
valve guide seals
I need to have valve seals installed on my heads and was wondering what the cost would be for a shop to do it? Or the time it would take to do it? the car emits blue smoke when you start it,rev the engine it smokes more. Could I have bad piston rings as well?
85 305tpi Trans am
flowmaster exaust
K&N air filter, 4:11 rear gears
Old Apr 6, 2001 | 08:09 AM
ede's Avatar
ede
call a shop in your area and ask, i'd say about 3 hours flat rate, but don't know for sure.
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
Old Apr 6, 2001 | 11:07 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Most likely it is your valve seals and guides. Mine does this too, I need to get it fixed. My suggestion would be to go to an engine shop and get a pair of rebuilt heads. They will take yours and give you the core charge for them. The shop I go to is City Motor Supply and their heads are $95 each after core charge. If your heads are cracked or anything and they can't take them then you will have to pay like 30 or 40 dollars more per head.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
hdis2002
Sep 8, 2015 02:52 PM
tgp1990
Sep 4, 2015 06:24 AM
