thinkin about new heads...could i use the guts from my old heads?
Old Jun 19, 2004 | 12:26 AM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
like i said im thinking about getting some new heads. im really interested in the Pro-Topline heads. i have the stock 76 sbc 350 heads on my car right now. i was wondering if i would be able to use the guts from my old heads and transplant them into the new heads. if not then how much more would it be to get them assemebled aproxximently?
also im 16 years old that makes 6 dollars an hour. im on a budget.
Old Jun 19, 2004 | 01:24 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I wouldn't do it, the springs are probably worn out, and not up to the task of performance. Also the valves are probably to small 1.94" or 1.84" vs. 2.02 for your PRO's.
Old Jun 19, 2004 | 06:54 AM
ede's Avatar
ede
it'd be a step backwards to reuse most if not all the parts in your old heads. if it were me i'd buy the heads bare. then you can buy the springs to match your cam, studs, some good valves like manely race flows, and all the small pieces then assemble them yourself.
Old Jun 19, 2004 | 10:16 AM
owned's Avatar
Re: thinkin about new heads...could i use the guts from my old heads?
When you take a ****, do you reuse the toilet paper you used the last time? Being on a budget and all.
Old Jun 19, 2004 | 10:45 AM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
sometimes
anyways thanks guys i relize that takin the guts from the old heads would be dumb. so ill save up.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
