cam expert needed
Old Jun 19, 2004 | 12:05 PM
25thanniversary's Avatar
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
cam expert needed
im building a carbed 305 and all im really doing is putting an edlebrock intake and edelbrock carb 1.94 intake valves and pocket porting my heads im looking for a cam that will make the most power but i can still use the car for daily driving any suggestions will help thanks
Old Jun 19, 2004 | 02:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Depending on transmission/stall, Xe262 or Xe268. Perhaps bigger depending on a few factors.
Old Jun 19, 2004 | 05:42 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Comp Cams Dual energy DEH265 Should work well in your motor. PN is 12-208-2
Will like a 3.42 or 3.73 rear gear ratio. A torque converter with a slightly higher stall is nice too but stock will do.
Old Jun 19, 2004 | 11:50 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Comp XE 262 is the max i would go bigger then that and you will lose power, not gain.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Fronzizzle
Aug 9, 2015 01:15 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
