Why does my car keep dieing?
Old Jun 19, 2004 | 05:37 PM
KahliFornyaKing's Avatar
Car: 1992 RS Camaro
Engine: 305 TBI
I bought my 92 RS camaro TBI about 3 months ago when it only had 46k miles on it. It was running fine till about a week ago when it puttered out and died on me after i started it. So i started it again and it ran fine so i didn't think anything of it. But yesterday it died on me again and after repeated times of starting it, it kept puttering out and dieing so i replaced the fuel filter and it worked fine till the next day when it started doing the same thing. I took off my air cleaner and watched the injectors after i strarted the car and they seem to be working fine till the car dies. Is it a fuel problem or an electrical problem? What should I do??
Old Jun 19, 2004 | 09:29 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
check your plugs to see what type of condition they're in
Old Jun 20, 2004 | 07:45 AM
ede's Avatar
ede
make sure your tune up is good, scan for codes, filters good, i'd check FP and volumn too.
Old Jun 20, 2004 | 12:27 PM
Car: 1992 RS Camaro
Engine: 305 TBI
thanks guys ill look into that as soon as i can. any other ideas? can i pick up a scanner at pep boys or auto zone?
Old Jun 20, 2004 | 12:35 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
dont buy a scanner... you're just throwing away money if you do. do the paper clip trick
https://www.thirdgen.org/faq/thirdgen.shtml#misc
Old Jul 5, 2004 | 02:13 PM
Car: 1992 RS Camaro
Engine: 305 TBI
I did the paper clip trick and all i got is a code 12, but before i could do that my friend disconnected the battery would that clear the codes? Also do you think it could be my fuel pump?
Old Jul 8, 2004 | 11:56 PM
Car: 1992 RS Camaro
Engine: 305 TBI
It was my fuel pump. I replaced it and the problem is gone! Thanks guys
Old Jul 9, 2004 | 09:19 PM
Dark_Knights's Avatar
Car: Camaro
Engine: 5.7 Liter 350 Chevy
Transmission: GM Turbo 400
fuel pump...is bad
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
