msd being a pain if you use one come in
Old Jun 21, 2004 | 10:50 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
i just recently put my msd 6al back on my car after having it off for a while. seems like it did nothing. however its also running hotter too. wich is very uncomon for my car. i dont think ive ever seen over 180* with it.its now running 190*. i have a 160* stat and the fan turns on at 160 as well. could this just be a problem that happend to develop at the same time. also theres a slight skip at mid rpms as well that i started to notice.
Old Jun 21, 2004 | 11:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What kind of distributor are you using?
Old Jun 22, 2004 | 07:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take it back off and see if things return to normal.
If so, then right there you have your answer.
Old Jun 22, 2004 | 11:52 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
its a stock vacuum adv distrubutor.
it think im gonna take it back off this weekend. i realy didnt want to but i guess thats the only sure way to see what the deal is. i will have to recrimp all my stock wires and stuff.lol. should have just left it alone it ran good before.
Old Jun 22, 2004 | 12:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It had a 4 pin module but now you're replaced it with the MSD harness? Try reversing the polarity to the magnetic pickup terminals on the MSD.
Old Jun 22, 2004 | 03:18 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
cant realy do it because the harness i bought was like 25 bucks and to do that i would have to cut it. the female connectors are different size. they only go on one way.
Old Jun 22, 2004 | 03:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I know, I have the same harness, it's the one that comes with the box. The MSD triggers on the rising edge of the reluctor signal, but I've seen quite a few 4 pin HEI distributors that produce a negative-going reluctor signal at firing time. In this case, the MSD triggers much too early on the rising edge, giving additional unstable advance which varies with RPM.
Old Jun 22, 2004 | 09:09 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
ok i get what your saying. that could explain a little detonation at mid range as well i guess. ill give it a try.
thx
Old Jun 23, 2004 | 01:38 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You don't have to hack up that harness if you don't want to, just rig something up. You could also compare your timing with and without the MSD.
Old Jun 23, 2004 | 10:28 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
yea im probraly gonna just make a jumper. then put the stock back on it. lately its been fine tho hasnt ran hot or misfired so i donno what it could be.
thx
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
