oil ascender leak fix
Old Jun 22, 2004 | 05:39 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
oil pressure gage sending unit leak fix
I think the oil is leaking at my oil pressure sending unit back by the distributor. It is not bad. Should I use teflon tape? Any ideas.
thanks,
phil
Old Jun 22, 2004 | 06:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Ah, "oil pressure gage sending unit".
If it's leaking past the threads and there's no damage, yes, Teflon tape can help.
Often, the pipe is cracked, causing the leak. Check it carefully when you have it off.
Old Jun 22, 2004 | 07:34 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
yea, isn't that what i said? Both had "oil" in the phrase. I will remove it and check it out. thanks.
phil
Old Jun 24, 2004 | 06:55 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Took off the sending unit and the brass pipe that attaches it to the block. Luckily their were know cracks in the pipe. Cleaned them both up and put teflon tape on the threads of the pipe and the sending unit. reinstalled and that seems to have fixed my leak. No leaks! I hate leaks.
Old Jun 24, 2004 | 01:31 PM
five7kid's Avatar
Another success story, brought to you by thirdgen.org...
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
MY87LT
Aug 17, 2015 08:43 AM
bamaboy0323
Aug 15, 2015 07:20 AM
drathaar907
Aug 6, 2015 04:20 PM
