Can't get center console out to install Ripper Shifter
Old Apr 7, 2001 | 02:42 PM
MY87GTA's Avatar
I bought a B&M Ripper Shifter for my 87 GTA but i can't install it because i can't seem to get the center console out, any help will be much appreciated. Thanks
Old Apr 7, 2001 | 03:09 PM
Guest
Guest
Posts: n/a
Well where are you at?
Theres one screw under the ashtray, and two under the console lid, then you can take the plastic cover plate up. Theres a bunch of wires in connectors under there you have to take off, be careful when you take the connectors off you could break the cover plate... Ive seen it happen before. Then there are two screws holding the console down in the bottom of the compartment and one screw in front of the compartment just behind where the shifter is, in a metal plate there.
I would take off the E-brake cover as well, its held on by one screw and will prevent you from scratching it up when you take the console out of the way.
Old Apr 8, 2001 | 12:57 PM
MY87GTA's Avatar
Ok, i took out the ones under the console lid but can't find the screws under the ash tray. I'll keep looking. Thanks
1992 Trans Am
May 10, 2023 07:19 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
colton_carlson
Mar 8, 2019 12:21 PM
Firebird sweden
Aug 16, 2015 05:02 PM
TheJoeY88
Aug 13, 2015 06:51 PM
