TPS Voltage won't go below .697 ??
Old Apr 8, 2001 | 07:29 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Is this bad ??
I cant "rotate" the sensor very much AT ALL...
and it will hardly change much
when I opened it up "the Throttle" it appeared to be smooth all the way maxing out at ~4.2 something
am I ok or is this going to effect anyhitng??
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Apr 8, 2001 | 10:18 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
anybody have any advice for this?
I know it;s supposed to be somewhere around .47-.52 I think something like that
anyway I know what it is I just dont have it in fron of me right now but I cant get anything lower than.69~ something
thanks!
Hecubus
[This message has been edited by Hecubus (edited April 08, 2001).]
Old Apr 8, 2001 | 11:30 PM
Vader's Avatar
Hecubus,
The '91 has a non-adjustable TPS. The ECM will scan the TPS at intitial power-up and use whatever value the TPS is providing for a "zero" position. The ECM is a bit more sophisticated than the older ECMs. As long as the initial voltage is below 1.0VDC, the ECM will use the position as a reference. Anything above 1.0V should eventually set a DTC. There is little benefit to adjusting the TPS as long as the WOT reading is more than 4.0VDC.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Apr 9, 2001 | 12:04 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Vader
thanks for the help that was one of my guesses because of it not being able to move the way it mounted to the TB but I really wasn't shure
thanks
Hecubus
Old Oct 21, 2011 | 04:21 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: TPS Voltage won't go below .697 ??
Originally Posted by Vader
Hecubus,
Later,
Vader
So if mine is at 0.70 at idle, going lower wont make it run better?
BumpaD82
Feb 26, 2016 02:57 PM
327IROC85
Sep 23, 2015 12:11 AM
ULTM8Z
Sep 16, 2015 09:15 AM
Formula_88AE
Sep 3, 2015 01:47 PM
