Mass Air Flow Sensor Troubles?
Old Jun 26, 2004 | 03:47 PM
pvv78's Avatar
Car: 1989 IROC-Z
Engine: 5.7L
Transmission: 700R-4
the Mass air flow sensor in my car is broken but car starts and runs fine with check engine light on, new MAF installed and car starts but stalls immedietly everytime. I can even unplug the MAF altogether and it also starts and runs. What is the problem?
Old Jun 26, 2004 | 05:06 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Probably your MAF relay(s).
Old Jun 26, 2004 | 07:14 PM
rsn932's Avatar
not really answering your question, but im just curious: did you get a new gm MAF or an aftermarket one and how much did you get it for? cuz im looking for a new one but they seem to be really expensive
thanks
Old Jun 26, 2004 | 08:47 PM
pvv78's Avatar
Car: 1989 IROC-Z
Engine: 5.7L
Mass Air Floew Sensor
I got it at Auto Zone. It is actually a remanufactored Bosch unit which seems to be a very good sensor, It was $150 plus 80 core charge. It was the cheapest one I found. They previously had one made by wells manufactoring which was a new unit for $60 but it is no longer avabile.
Old Jun 26, 2004 | 09:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Micro-Tech makes one that is carried at Advance Auto for about $170.00 (no core charge) with a limited lifetime warranty. It goes bad take it back for another one.
Old Jun 26, 2004 | 10:17 PM
Merlin's Avatar
http://www.wellsmfgcorp.com/counterp...erpoint3_2.pdf
Old Jun 27, 2004 | 12:34 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Re: Mass Air Flow Sensor Troubles?
Originally posted by pvv78
...new MAF installed and car starts but stalls immedietly everytime. I can even unplug the MAF altogether and it also starts and runs. What is the problem?
I assume you have already bought and installed the new MAF sensor. You need to replace one or both of your relays.
Old Jun 27, 2004 | 05:30 AM
vampiroc's Avatar
Car: Z28
clear the codes too with the ECM connector. IIRC it's a black to orange connector and its near the battery. just unplug with car off and plug back.
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
