Oil Leak
Old Jun 26, 2004 | 08:53 PM
berklified's Avatar
Oil Leak
Guys I seem to have a tiny oil leak somewhere below the exhaust manifolds on my '87 5.7L 350
the solenoid and starter have a coating of oil
where is the most likely oil leak area on this engine.
Old Jun 26, 2004 | 10:25 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Oil Leak
Sounds like it could be leaking from the back of the manifold, probably at the china wall. Have you changed the manifold recently? Try tightening the manifold to see if it stops.
Old Jun 26, 2004 | 11:06 PM
berklified's Avatar
source found
alright so i found out where the leak is
there seems to be smoke coming from underneath the passenger side valve cover
as well that is where the majority of the oil is
what and where is this china wall and how do i tighten it?
although i did find alot of transmission fluid, that's what it seemed to be
how does transmission fluid leak from the valve cover?
what do i need to do to fix this?
i tried tightening the valve cover screws, they are on there rock solid
please help, this is my everyday runner
Old Jun 26, 2004 | 11:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If it has perimeter bolt valve covers then the valve cover gasket surface is probably all bent up and bottomed out on the head. Flatten out the gasket surface and replace the gaskets adn that should fix it. The center bolt gaskets turn to crust after a really long time and they need to be replaced every so often as well.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
